Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How can I choose quadrant
3 REPLIES 3
891 Views, 3 Replies
my project fusion 360 Autocad
Hi guys I have gat a project in fusion 360 I can use AutoCad My problem is: I can't assemble Bearing on rail because I cant choose bearings quadrant fusion 360 everytime choose center I cant choose Quadrant can you help me please good luck
3 REPLIES 3
brianrepp
@Anonymous I moved this post from the Tips section to the Design & Doc forum for better visibilty.
in reply to: brianrepp
You are right thanks
innovatenate
Hello and welcome to the Fusion 360 community!
From your screenshot and comments below, it sounds like you are trying to assemble a design with Joints, but find that you're unable to utilize the quadrants of a circular edge to create the Joint between a bearing and the disk/rail. Does that sound correct?
An easier approach may be to use the Rigid Group feature to create a series of components that are Rigidly "glued" together. After doing this, it seems that you would only need one joint: a revolute or cylindrical joint to assemble the components.
If you really need to get to a quadrant of a cylindrical edge, it could be done by manually creating Joint Origins (see assembly menu) in those roller components at the correct location. It may be necessary to first create a sketch and manually add points at the quadrants. After doing this, you would be able to create new Joints utilizing the Joint Origins.
I hope this helps! Let us know if you have any questions.
Nathan Chandler
Principal Specialist
