Hi guys I have gat a project in fusion 360 I can use AutoCad My problem is: I can't assemble Bearing on rail because I cant choose bearings quadrant fusion 360 everytime choose center I cant choose Quadrant can you help me please good luck
Hello and welcome to the Fusion 360 community!
From your screenshot and comments below, it sounds like you are trying to assemble a design with Joints, but find that you're unable to utilize the quadrants of a circular edge to create the Joint between a bearing and the disk/rail. Does that sound correct?
An easier approach may be to use the Rigid Group feature to create a series of components that are Rigidly "glued" together. After doing this, it seems that you would only need one joint: a revolute or cylindrical joint to assemble the components.
If you really need to get to a quadrant of a cylindrical edge, it could be done by manually creating Joint Origins (see assembly menu) in those roller components at the correct location. It may be necessary to first create a sketch and manually add points at the quadrants. After doing this, you would be able to create new Joints utilizing the Joint Origins.
I hope this helps! Let us know if you have any questions.
