These were made in Solidworks and I was wondering if Fusion can do the same thing? The holes are marked, then added to a table instead of cluttering up the drawing with arrows.
Solved by aaronkcap. Go to Solution.
Yes, but the current way is kind of tedious to do. Place a text box next to the hole and then label it; after that go to tables menu and select table, then from the ui box click where it says reference and select empty table and populate it. I know it can be a lot of work especially in the design from the picture but it is the only way that I know of to do that.
