Timeline Glitch
Timeline Glitch
ninolemann
Timeline Glitch
ninolemann
Hello Everybody,
I have Timeline Troubles:
Sometimes, when i jump to the end of the timeline, the only remaining command left visible is the last in the line. It looks like there should be a scroll bar, but there isnt. i can get to previous commands by pressing the reverse button on the timeline command, and then again forward. like this, all the commands stay visible.
Is this a glitch, or is this something with purpose??
Greetings,
TrippyLighting
You mean the actual timeline marker goes amiss ?
If that's the case, at least on macOS that is a very old bug.
ninolemann
No, the marker is still there, but i can only see the last command i used.
i can then put the marker previous (left) or after (right) of that command.
When i press the 'previous step' button, the second-to-last command appears as well, and stays visible.
when pressing the forward button, all commands appear again.
what is this???
 i made a screencast, but cant upload it. try again later
ninolemann
Finally,
The screencast works.
There you go
ninolemann
an again, this time with screencast actually ttached
laughingcreek
That looks glitchy to me too.  Does it keep happening if you toggle "hide all inactive features"?
ninolemann
That was already toggled on.
But its not happening when its toggled off.
