Hi everyone. I hope you can help/advise on this.
Firstly, I have been using Rhinoceros 3D for 10+ years and that affects my workflow (at least in this case) and I am on my fourth week of using Fusion 360. Though, this way of working, my "Rhino-workflow", seems legit as Fusion embraces many CAD approaches. I am working with bodies with no thickness as my goal is a shell chair with the same thickness troughout the shell and I will thicken to shape later.
I have created two T-Splines surfaces, that I want to connect. I have tried different approaches, but I lack control of the way the new surface meets the two existing and while still being able to control the radius of the bend (see attached images). In Rhino I would do a 2 Rail Sweep or a Blend Surface, both with numerous profile curves if needed. But I can't find a tool capable of doing the equivalent in Fusion 360.
The first image is where I am right now, trying a simple Patch Loft with two profile curves and two edges from the existing surfaces.
Image two shows my goal created by my colleague/boss in Cinema 4D.
The rest of the images shows my other failed approaches, T-Splines Bridge, T-Splines Sweep + Match, Patch Loft and T-Splines Edit Face. Ideas to control the radius of the bend and how the new surface meets the two existing are more than welcome. And even completely different ways of doing the chair, but I had a hard time getting my head around doing this with parametric design with sketches.
