I have read a number of posts that joining of line segments is not available in fusion 360 and that it is a workflow problem. I am struggling to understand how to apply this workflow issue to the problem I have at hand.
I have created a parametric curve representing a portion of a pattern I want to create.
I then want to mirror this on the other side to replicate the pattern exactly
So far so good! Now, I want to repeat this pattern in a circular fashion to produce the final pattern
This is what I am after, and I need these segments to all be joined so I can extrude this, but without line segment joining capability, what should my workflow be to accomplish this same thing and keep it parametric?
Solved by jeff_strater. Go to Solution.
You can extrude without having a single curve segment (these are not "lines"). But, the pieces that you are patterning must match geometrically. I suspect that you have gaps in your pattern. If you share the design here, we can look at it.
Yes, I do have a very small overlap (not a gap), where I didn't calculate the width of the pattern based on the number of patterns within the circle (which is just the arclength/number of segments / 2) because I didn't know how many I wanted initially. So what you see is this when zoomed all the way in:
Are you saying that if I get the formulas correct where this is precise, then these repeated spline segments will then join?
(I will upload the file here shortly)
"Are you saying that if I get the formulas correct where this is precise, then these repeated line segments will then join?"
No, they will not "join", in that they will not become a single curve object. But, they will define a closed profile which can be extruded. Overlap is OK. Gaps are not.
as an example, I created this sketch. I added the construction lines so that I know the pattern will be exact:
Because that angle is 30 degrees, I know that I need 12 instances to the pattern (12 * 30 = 360)
after creating the pattern, you can see the shaded profile area:
which can then be extruded:
and to illustrate the point about overlaps, if I change the curve so that it overshoots the points, it still defines a profile:
It was WAY more simple than that. This sketch just seems to have "Show Profile" turned off. If you turn it back on, it works. I always forget to ask people to check that.
@LazyRiverLife wrote:
I have read a number of posts that joining of line segments is not available in fusion 360 and that it is a workflow problem. ...
There are a number of post about "joining" sketch elements, but none show how it is a workflow problem. Mostly it is a user not understanding how to use the software to achieve their ends, and think that being able to "join" the segments is somehow the answer.
on a side note, mirroring and patterning fit point splines tends to lead to splines that aren't actually mirrors or perfect patterns (not sure if we're calling that a bug or limitation these days). A control point spline will work. better option is to draw it once, and do the mirroring and patterning in the solid environment, but I digress..
I agree and thus my question, however, there are some basic operations that are fairly common in (non parametric) drawing apps which don't carry over to F360. For example, converting a point on a spline to be a straight point, or a line segment to a spline, or as in this question, joining splines/lines etc.
This is a very typical drawing operation that most people are familiar with and it can be frustrating when it is missing. For the newcomer to F360 it is a big learning curve, and sometimes better if you didn't have prior vector drawing experience.
I am by no means an expert, but I have really enjoyed the F360 environment. I love the parametric modeling. It makes me think a little more clearly about what I am doing rather than just drawing something up. I have caught so many of my design issues by modeling first; tweaking the parameters; and then finding out that it doesn't scale right. You just can't do that in a vector drawing app.
