Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Help with workflow for repeated line segments since no join available?
11 REPLIES 11
Message 1 of 12
LazyRiverLife
391 Views, 11 Replies
I have read a number of posts that joining of line segments is not available in fusion 360 and that it is a workflow problem.   I am struggling to understand how to apply this workflow issue to the problem I have at hand.
I have created a parametric curve representing a portion of a pattern I want to create.
I then want to mirror this on the other side to replicate the pattern exactly
So far so good!   Now, I want to repeat this pattern in a circular fashion to produce the final pattern
This is what I am after, and I need these segments to all be joined so I can extrude this, but without line segment joining capability, what should my workflow be to accomplish this same thing and keep it parametric?
Tags (3)
11 REPLIES 11
Message 2 of 12
You can extrude without having a single curve segment (these are not "lines").  But, the pieces that you are patterning must match geometrically.  I suspect that you have gaps in your pattern.  If you share the design here, we can look at it.
Jeff Strater
Engineering Director
Message 3 of 12
Yes, I do have a very small overlap (not a gap), where I didn't calculate the width of the pattern based on the number of patterns within the circle (which is just the arclength/number of segments / 2) because I didn't know how many I wanted initially.    So what you see is this when zoomed all the way in:
Are you saying that if I get the formulas correct where this is precise, then these repeated spline segments will then join?
(I will upload the file here shortly)
Message 4 of 12
"Are you saying that if I get the formulas correct where this is precise, then these repeated line segments will then join?
No, they will not "join", in that they will not become a single curve object.  But, they will define a closed profile which can be extruded.  Overlap is OK.  Gaps are not.
Jeff Strater
Message 5 of 12
jeff_strater
in reply to: jeff_strater
as an example, I created this sketch.  I added the construction lines so that I know the pattern will be exact:
Because that angle is 30 degrees, I know that I need 12 instances to the pattern (12 * 30 = 360)
after creating the pattern, you can see the shaded profile area:
which can then be extruded:
Jeff Strater
Message 6 of 12
jeff_strater
and to illustrate the point about overlaps, if I change the curve so that it overshoots the points, it still defines a profile:
Jeff Strater
Message 7 of 12
Ok, then I am not sure why mine did not become a closed profile. I don't see where there are any gaps.
Message 8 of 12
*removed*
Yeah, not sure how to approach this in my case.
Message 9 of 12
It was WAY more simple than that.  This sketch just seems to have "Show Profile" turned off.  If you turn it back on, it works.  I always forget to ask people to check that.
Jeff Strater
Message 10 of 12
DOH!      I totally spaced that out.
Thanks!!
Message 11 of 12
@LazyRiverLife wrote:
I have read a number of posts that joining of line segments is not available in fusion 360 and that it is a workflow problem. ...
There are a number of post about "joining" sketch elements, but none show how it is a workflow problem.  Mostly it is a user not understanding how to use the software to achieve their ends, and think that being able to "join" the segments is somehow the answer.
on a side note, mirroring and patterning fit point splines tends to lead to splines that aren't actually mirrors or perfect patterns (not sure if we're calling that a bug or limitation these days).  A control point spline will work.  better option is to draw it once, and do the mirroring and patterning in the solid environment, but I digress..
Message 12 of 12
I agree and thus my question, however, there are some basic operations that are fairly common in (non parametric) drawing apps which don't carry over to F360.   For example, converting a point on a spline to be a straight point, or a line segment to a spline, or as in this question, joining splines/lines etc.
This is a very typical drawing operation that most people are familiar with and it can be frustrating when it is missing.   For the newcomer to F360 it is a big learning curve, and sometimes better if you didn't have prior vector drawing experience.
I am by no means an expert, but I have really enjoyed the F360 environment.   I love the parametric modeling.  It makes me think a little more clearly about what I am doing rather than just drawing something up.   I have caught so many of my design issues by modeling first; tweaking the parameters; and then finding out that it doesn't scale right.     You just can't do that in a vector drawing app.
Technology Administrators
