Help with this part
Help with this part
FacebookGroupMember
Message 1 of 21
Help with this part
FacebookGroupMember
I need two plate mould with stripper ejection help me please u may understand my intention .
Please....
Replies (20)
Message 2 of 21
jhackney1972
You will need to attach your model.  If you do not know how to attach your Fusion 360 follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
Message 3 of 21
TheCADWhisperer
I would probably add some draft (release angle) to the original part.
Of course  you will need to show what you have done so far to get additional help.
Can you ask your instructor to join this discussion?
Message 4 of 21
TheCADWhisperer
Message 5 of 21
FacebookGroupMember
https://a360.co/3kOg4nw
Now can u help me runner and gate
Message 6 of 21
TheCADWhisperer
Why yes, I can help you with that.
Message 7 of 21
FacebookGroupMember
Instructor don't know about mould it's my project work
Message 8 of 21
TheCADWhisperer
Is it too late to change schools?
I did not see your Spoon component Attached here.
https://forums.autodesk.com/t5/forums/replypage/board-id/124/message-id/242350
Did you Attach the file?
Message 9 of 21
can u send mould assembly file
Message 10 of 21
TheCADWhisperer
Message 11 of 21
ok sir
Message 12 of 21
TheCADWhisperer
That is not a CAD format file?
That is the same image that you posted originally.
I need to see the CAD file of your work.
I have already modeled it myself, but I passed this class a longgg time ago...
Message 13 of 21
fusion file component
Message 14 of 21
sir i desgined in fusion 360
jion in link i am sending now
https://a360.co/3egGKfs
Message 15 of 21
TheCADWhisperer
Has your instructor taught how to use Fusion 360?
Sketch1 does not have any dimensions?
There is (almost) never any need to use a Move command.
Sketch2 is empty?
Shell done at the wrong time (before Fillets).
Sketch3 is empty?
Sketch4 does not have any dimensions?
Sketch5 is not fully defined?
Another unnecessary Move?
An incorrect Fillet that results in very thin corners?
...and doesn't match the drawing?
Message 16 of 21
sir now i given edge radius
can u please share your phone number
please....
Message 17 of 21
FacebookGroupMember
Can u send fusion 360 file
Message 18 of 21
TheCADWhisperer
Message 19 of 21
FacebookGroupMember
Each edge radius 2 mm
Message 20 of 21
FacebookGroupMember
There is no radius
