HELP! with modeling on fillet
Message 1 of 8
I am a beginner at modeling and am trying to connect the line from one plane to model onto a fillet which is at an angle . Is this possible?
I will like the extruded lines and dots to connect across the fillet portion to the top and over to the other side
Replies (7)
Message 2 of 8
g-andresen
try this way:
1. Cut & Mirror
To close the gap you have to create a sketch and project the cut out into. Then the corresponding part is extruded into the existing gap.
2. maybe pattern on path is the tool for part 2
günther
Message 3 of 8
my issue is more so the fillet portion of the slide. I will like to sketch the engrave lines on the side in the fillet portion as well fillet.png
Message 4 of 8
g-andresen
no problem:
Sweep is your friend.
Screencast
günther
Message 5 of 8
That's awesome thanks a million! Now will that work for the small circles on the side as well?
Message 6 of 8
g-andresen
I hope, that´s what you´re after.
Important:
günther
Message 7 of 8
Yes this is what I wanted, if you don't mind telling me how you got this done for future projects
Message 8 of 8
g-andresen
The path for the pattern was set in article 4.
Take a look at the screencast and the timeline.
The path is used for both patterns, which can be seen in # 6 (screencast & file).
günther
