Multiple selections -Printting problems
I'm doing my first model using Fusion 360. Learning, or al least, trying. I made a model about mercedes. benz 280 sl 1970's basically 3 parts, Left, Right and the Roof, them the tires. I got the version I named v40 and I could obtain the STL to be printed. A couple of day latter I try again and it's being impossible apparently due to Multiple Selections.... what I can't understand is why? If the original file (model) is the same?, could it be a matter of wifi, memory, ?? could anybody help me, thank you very much
Ajay_Kumar_Reddy
1.You can export only one body for converting it into .stl, if it is having multiple bodies you can join them to get a single body.
2. Fusion will no allow you to select multiple bodies at a time to convert, though you can convert all individually one by one.
3. You can print all the bodies at once by bringing all the stl's which were converted in mexmisher.
If you were unable to join them? Just add me to your project trust me I can help you with it pal.(ak47bhoom@gmail.com)
laughingcreek
exporting from the component level allows you you to export multiple bodies in one go.  right mouse click on the component containing the bodies instead of the individual bodies.  or rightmouse click on the top level component (first item on the browser tree) to export all the bodies in the project at once.
Thanks a lot for your help. I ve been success with this way. Tank you very much. Pablo
Than you for trying to help, ,I really appreciate, much being somebody with very low knowledge, finally the solution was around to capture from de "body" first alternative in bellow the browser as other coleage of you mention. Even that I really appreciate you interest and effort trying to help. Regards. Pablo
