Help with Fillet
Help with Fillet
FacebookGroupMember
Help with Fillet
FacebookGroupMember
Hi. Still new to Fusion 360. I went through that 16 tutorial series on Youtube, and I was feeling pretty good, but, decided to build my first shape today, and I guess I still have a lot to learn. How do I fillet the edge of a constructed object? I want to bevel, if you will, the top outside edge of the smaller shaft. I pick the fillet tool, but I am unable to select any edges with it. Does this have something to do with not being in sketch mode?
FacebookGroupMember
In your pick you are in sketch mode it's under solid - create you have to exit the sketch first.
FacebookGroupMember
You are in sketch mode. In sketch mode you can only filet a vertex between 2 lines (but you probably shouldn't). Exit sketch mode first.
