And for my next question...how can I move the line that is highlighted blue
FacebookGroupMember
FacebookGroupMember
And for my next question...how can I move the line that is highlighted blue. The move tools has an option for faces, but I need to move JUST that line. I want that face next to it to be a little sloped. So...I don't see any constraints pop up. I'm guessing that only happens in the sketch. This is the object.
FacebookGroupMember
Instead of trying to move the line try applying a chamfer. You will want to change the options to get a non-uniform chamfer (I don't remember the specifics & don't currently have access to look it up).
FacebookGroupMember
Ron Burt I actually decided to redraw it as a slice and then do a rotation around the y axis. This was out side the relm of what I understood when I posted this a while ago, but I got the idea from a tutorial and wanted to try it. It worked much better than this sketch did. However, for practice, I may go back and try what you have suggested. Thank you.
FacebookGroupMember
Kevin Cantrell
Many ways to accomplish most designs.
FacebookGroupMember
Ron Burt The Chamfer worked VERY well at accomplishing the same thing.
