Go to the sculpt environment and start with a box
set the view to front, side or top, whatever you need, and then use the edit form tool to get to your shape
I recommend you use the attached picture as a canvas
Saeed Hamza
Hi Jason,
Here is another variant, which is a bit clearer for the beginning.
Activate the edit mode of the loftfeature in the timeline.
You will see what the centerline does when you turn it off and on again.
Evenso you can edit the distances of the planes.
good succeed
günther
Here is a small overview of the attached file.
