help with drawing a leg
Message 1 of 14
new to fusion and haven't used sculpt trying to design a leg to use with furniture hopefully image has uploaded please give me some tips..
Replies (13)
Message 2 of 14
etfrench
For that shape, using the Revolve command would be easiest.
ETFrench
Message 3 of 14
g-andresen
Hi Jason,
This is the way of etfrench, using the image.
günther
Message 4 of 14
Yea I thought that but it needs to shape in at the back not the out
Message 5 of 14
SaeedHamza
Go to the sculpt environment and start with a box
set the view to front, side or top, whatever you need, and then use the edit form tool to get to your shape
I recommend you use the attached picture as a canvas
Saeed Hamza
Message 6 of 14
etfrench
Can you explain that better.  Section drawings at the bottom, middle, and top would help.
ETFrench
Message 7 of 14
What do you mean sorry
Message 8 of 14
etfrench
Your image only shows the side profile of the leg.  What are the profiles looking down from the top?
ETFrench
Message 9 of 14
see attached image bottom of leg and top of leg
Message 10 of 14
all image I have off leg its 400mm long
Message 11 of 14
g-andresen
Hi Jason,
here is a model to play with.
have fun
günther
Message 12 of 14
thank you so much günther.
is it is to do a video sometime on how this was made for any other ones.
I need to learn a lot
Much appreciated
Message 13 of 14
g-andresen
Hi Jason,
Here is another variant, which is a bit clearer for the beginning.
Activate the edit mode of the loftfeature in the timeline.
You will see what the centerline does when you turn it off and on again.
Evenso you can edit the distances of the planes.
good succeed
günther
Here is a small overview of the attached file.
Message 14 of 14
thank you that's brilliant just need to work out how you got that all to join with centreline and all your sketches. also where do I activate sketch pallet
