Help with 90° loft with different diameters
Message 1 of 13
Hi, I am having an issue with creating a 90° loft when the diameters are different.
The ending result is either unrealistic or  has auto-insertecting geometries that I can't subtract/join.
I just want a result that would happen if you would try to bend a metal rod..
This is the best I could do, which I am not satisfied with as the intersection is weird.
ANy tips on how to make it? Thank you.
Replies (12)
Message 2 of 13
TheCADWhisperer
Message 3 of 13
I'm not sure what it would be useful for, it's just a generic question for any 90° loft with different diameters..
Message 4 of 13
laughingcreek
it would help people directly answer your question without having to create an example model from scratch.
Message 5 of 13
laughingcreek
this is probably as realistic as your going to get, but probably not worth the trouble.
Message 6 of 13
Oh, I never saw those modeling features.... so I guess there is no way with loft? Because I do 90° features with different diameters very often and it's hard.
Message 7 of 13
jhackney1972
I guess I will throw one into the pot to be considered.  Model is attached.
John Hackney, Retired
Message 8 of 13
TheCADWhisperer
No example file Attached?
Message 9 of 13
shahriarsifat1802164
Can you please share your model?
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 10 of 13
RUET
Thank you.
Message 11 of 13
RUET
Thank you.
Message 12 of 13
I am providing a screencast please have patience.
Thank you.
RUET
Thank you.
Message 13 of 13
Loft with 90 degree angle | Fusion 360 | Autodesk Knowledge Network
RUET
Thank you.
