Help filx dxf cutting text!
malinen89
Message 1 of 13
malinen89
hi can someone help me fix this dxf file. there are problems with some of the letters 😞
Replies (12)
Message 2 of 13
g-andresen
What is a mistake from your point of view?
I can't see one.
günther
Message 3 of 13
malinen89
here you see the problem 😃
Message 4 of 13
g-andresen
here´s a f3d file
günther
Message 5 of 13
jhackney1972
I am with @g-andresen, the DXF opens in both Fusion 360 and AutoCAD 2023 without issue and is complete.  What application are you seeing the issue?
John Hackney, Retired
Message 6 of 13
malinen89
Hi thanks for the reply. the problem occurs when i import the dxf file into my nest program. EasyNest pro. You can see in the picture I uploaded earlier. It seems that the lines do not sit together where there is a radius.
Message 7 of 13
g-andresen
The problem probably lies in the amount of control points of individual elements.
I have reduced them in V-Carve-Pro.
günther
Message 8 of 13
malinen89
Okay now it works thanks !. What did you do and why do you have to do that? 😃
Message 9 of 13
g-andresen
The upper curve consists of a large set of (very short) line segments. If these segments do not have a "harmonic" transition, it can cause interference in further processing.
I converted the contours to paths with simultaneous change of resolution.
günther
Message 10 of 13
malinen89
Okay, I think I understand. I will try to learn this. But if you want you can help me with this hehe 😃
Message 11 of 13
g-andresen
Here is a (hopefully) working variant.
günther
Message 12 of 13
malinen89
The D and S dont work 😞
Message 13 of 13
g-andresen
try this version.
I have corrected some (apparently) critical areas by hand because numerous duplicate vectors could not be removed cleanly, which led to chaotic conditions when connecting them.
Screencast
günther
