heal a sweep that joins itself (wave spring)
7 REPLIES 7
Message 1 of 8
worknstuff
261 Views, 7 Replies
looking for tips on how to heal where the sweep rejoins the start of the sweep.
7 REPLIES 7
Message 2 of 8
blaster701
in reply to: worknstuff
A quick solution might be to do a sweep 90% of the way, then loft the remaining 10% and stitch?
Message 3 of 8
worknstuff
in reply to: blaster701
i'll check it when fusion has finished maintenance in couple hours - thanks!
Message 4 of 8
etfrench
Turn off "Shaded with Shaded with Visible Edges Only".
ETFrench
Message 5 of 8
davebYYPCU
Change Visual Display > Shaded.
I found nothing amiss with this Sweep.
@blaster701 is 90% a magic number?
Message 6 of 8
worknstuff
ok, i just get pedantic, as some suppliers produce exactly what the step shows.. i've just checked the step export in edrawings and it's all good. thanks for the help!
Message 7 of 8
blaster701
in reply to: davebYYPCU
No magic number, just do a test and see if it works. A sweep back to itself (starting point) could have many human issues. Starting plane? Guide line tangency?
Run a test.
Message 8 of 8
TrippyLighting
Such a sweep creates a NURBS surface. The “lines” simply indicate the beginning and end of then NURBS surface. There is really no way around this in any CAD software I know and it isn’t a problem, because if modeled correctly the surfaces are usually at least tangent across the seam.
What the other posters suggest does not eliminate the seam, it simply hides it from view.
