looking for tips on how to heal where the sweep rejoins the start of the sweep.
Solved by davebYYPCU. Go to Solution.
A quick solution might be to do a sweep 90% of the way, then loft the remaining 10% and stitch?
i'll check it when fusion has finished maintenance in couple hours - thanks!
Change Visual Display > Shaded.
I found nothing amiss with this Sweep.
@blaster701 is 90% a magic number?
ok, i just get pedantic, as some suppliers produce exactly what the step shows.. i've just checked the step export in edrawings and it's all good. thanks for the help!
Such a sweep creates a NURBS surface. The “lines” simply indicate the beginning and end of then NURBS surface. There is really no way around this in any CAD software I know and it isn’t a problem, because if modeled correctly the surfaces are usually at least tangent across the seam.
What the other posters suggest does not eliminate the seam, it simply hides it from view.
