Get temperature vs time graph from a thermal simulation
Capture.JPGHello,
I want to get the temperature vs time graph out of a thermal simulation that i made on Fusion 360. Is there any feature that I have to install or where is that command on Fusion 360?
Haad_Ali
@Anonymous I don't think so that there is any way of getting the graph of temperature vs time in thermal stress case study in fusion 360 simulation. But, you can generate the full details of all the results, constrains, loads from the report option in the result tool.
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
Fusion only performs a steady state heat transfer analysis. There is only one result: after an infinite length of time.
To perform a transient heat transfer analysis where loads and results change over time, you need to use either Inventor Nastran of Autodesk CFD.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
