Fusion 360 Simulate with Shell Elements
mstrauch4U8VY
Observer Observer
mstrauch4U8VY
Observer
Observer
I am trying to perform a structural analysis in Fusion 360 on a large honeycomb shape and would like to mesh each cell wall as a shell element as it is extremely thin in one dimension. I think I can mesh shell elements in the design phase, but I believe I have to generate a new mesh in the simulate phase and I cannot see where to create a shell element (or something similar). See attached file as a small subset of this honeycomb structure. Note that the full structure has more than 10k cells.
TrippyLighting
I am tagging @John_Holtz , but I believe this is not the type of analysis you can or should do in Fusion 360.
John_Holtz
Autodesk Support
Autodesk Support
Hi @mstrauch4U8VY . TrippyLighting is correct. Fusion can only generate solid elements in the simulation.
I suggest that you use Inventor Nastran for an analysis with shell (and composites if appropriate).
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
