Fusion 360 install problem
Message 1 of 45
When I try to install Fusion 360 from the link in the activation email (subject: Your Fusion 260 Account is Ready!), I get a dialog with
Unexpected Error
HTTP Error 403: Forbidden.
Please attach the file ".\streamer.log" to any problem reports before closing this dialog.
A search of my computer fails to find streamer.log.
I'd appreciate some help with this.
Thanks.
Replies (44)
Message 41 of 45
baribak
Just to confirm the log file has been analyzed and the customer contacted.
Kevin Baribault
Fusion 360 Quality Assurance
Message 42 of 45
G'day,
Same problem here.
Are you running the installer via the Fusion 360 Client Downloader? Or are you installing from the Mac AppStore?
I have tried both.  The Installer either gives the first attached message before it starts downloading or the second one after it is 99% downloaded.  The AppStore gives an error message after 99%.
Also, what are you seeing when you try to install? Does it start then stop? Never starts?
See above
And what kind of network are you running on? Office? Home? Public?
Home.  imac Yosemite V 10.10.5.  There are no other computers connected to mine.
Has Fusion ever run on this system?
No
Finally, there should be a log file created under /users/username/library/logs called autodesk.webdeploy.streamer.log. If you find it can you attach it here?
Attached.
Thanks for your help.
rob
harryproa@gmail.com
Message 43 of 45
baribak
Hi Rob,
From the log we are seeing an issue with authentication. Specifically we are not receiving the confirmation back from the server that we expect and so we shut down thinking we're not talking to the correct one. This process can be blocked by a firewall setting or a transparent proxy in use which uses "fake" certificates. Could either of these apply?
Kevin Baribault
Message 44 of 45
I'm having the same problem installing fusion 360. streamer.ext has stopped working.
Unexpected Error
Message 45 of 45
lazykranch149
Observer
Observer
I am trying to install Fusion on a new Mac mini M4 Pro. it keeps failing to install and gives me an error (see attached screen shot). Does Fusion work on this Mac?
