From Remake to CAM in FUsion
Message 1 of 9
Hi there
I have scan from Autodesk Remake and imported to Fusion. When I go to CAM its not selecting the surface its actualy saying that
there is no surface object so I thing the mesh is in wrong format.
Would someone know how to convert the mesh into a proper surface for CAM?
Thank you very much guys
Replies (8)
Message 2 of 9
Steinwerks
@lars_christensen did a video on this sort of thing not too long ago. Hopefully it contains the information you're looking for as personally I have very little experience with meshes in Fusion 360.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 9
Thank you very much for this video well the problem is that I have found it before and did the same as instructed but its not workning for me I dont undersstand what am I doing different.
Iam going through it now again so will let you know the result 🙂
Message 4 of 9
Steinwerks
Since the real issue at hand here is the importation of geometry I am going to flag the post and see if it can be moved to the Design subforum as there will certainly be more skilled users in this regard than here in the CAM subforum. But keep it updated, I'm curious to know what the issue is and how it's solved.
Neal Stein
Find me on:
Message 5 of 9
Almost forgot
when I click on the imported quad mesh object in fusion to convert and confirm the following form it shows error see the attach
I would say that the Remake is not converting it into quads because the error says 0 quads_?
Message 6 of 9
PhilProcarioJr
@Anonymous
Click your name in the upper right corner and select preferences, then uncheck auto triangulate meshes on import.Untitled.png
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 7 of 9
cekuhnen
@Anonymous
Hi there - I am a ReMake user myself.
I assume based on what you said sofar you exported from ReMake with Quadmesh export OBJ for Fusion 360. Right?
You imported a triangulated version into Fusion as evident in your screenshot.
As @PhilProcarioJr  stated there is an option in preferences to turn auto tessellation off.
When working with T-Splines you really only want to work with Quads. Currently it has problems dealing with triangle and ngon faces.
Let us know how things work out.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 8 of 9
Hey man thats it!!! This was the magic :-))))) I DO NOT LIKE CHECK BUTTONS 🙂
Message 9 of 9
Perfect your solution works cool and this guy Philprocario fix the problem with the triangulars 🙂
