setting dimentions
setting dimentions
georgeENF84
setting dimentions
georgeENF84
Hi, I sketched a rectangle around the size of my part I put in the correct dimensions no problem, there about a dozen holes in the part so I went and put them all in, put in all the proper diameters again no problem .... then I tried to dimension where the holes go on my rectangle .... I went to create sketch. selected a plane, selected dimensions in the sketch box, selected the center of a circle, selected a side wall of my rectangle, moved my mouse the dimension came up, I clicked on the dimension to change it and it gave me an error message "Adding this dimension will over constrain the sketch" I took exactly the same steps when I sized my rectangle ... no problem  ... I know I am missing something .... any suggestions ..... Thank You, George
TheCADWhisperer
It sounds like you are trying to dimension location after creation rather than before creation (or at time of creation).
georgeENF84
Attached you will find the file .... Thank you
TheCADWhisperer
Your circles are in Sketch1 - so that is where you dimension the locations.
Delete Sketch 2 and 3.
Right click (or double click) on Sketch1 and select Edit Sketch.
Hit d on the keyboard and start adding your location dimensions.
georgeENF84
Thank you
that was it 🙂
