Joint behavior not expected
smallfavor
smallfavor
I’m trying to manipulate a series of joints but the behavior is not whats expected by moving the components.  I’ve tried to tweek the joints but I continue to get this strange behavior.
jeff_strater
This is actually pretty much what I would expect of this joint system.  You have a lot of freedom in this assembly, so when you drag on just one component, I would expect the others to move as well.  If you want to control only one joint, I would use Drive Joint as the way to do it.
Jeff
Jeff Strater
Engineering Director
smallfavor
The issue I'm having is the unintuitive nature of the joints reaction to the mouse movement.
