Free add-in: mSt sketchTools
Message 1 of 16
I am pleased to offer the Fusion 360 community a free add-in: mSt sketchTools.
The add-in includes three easy-to-use commands:
  • Source of sketch-plane recognizes which planar entity was used to create a sketch-plane.
    This allows to identity links between components/bodies/sketches (e.g. in a top-down design).
  • Break sketch-links makes it possible to break the links of all projected elements in a single operation.
  • Measure sketch-curves displays the total length and length of each segment of a connected curve.
Free download via Autodesk App Store
Support page with additional information
Source of sketch-planeSource of sketch-plane
Break sketch-linksBreak sketch-links
Measure sketch-curvesMeasure sketch-curves
Replies (15)
Message 2 of 16
TrippyLighting
Very useful! I really like the documentation, explaining the not so obvious things that can get in the way of the tool.
Message 3 of 16
etfrench
Feature RequestSmiley Happy  Enable copy to get the contents.
ETFrench
Message 4 of 16
Thanks for downloading my add-in and for your feedback.
Unfortunately, I'm not sure I understand your request correctly (maybe because it's the end of a long day and my brain needs some sleepSmiley Frustrated).
To which of the three commands your request refers? Does "content" refer to the text output in the dialog?
Sorry for the inconvenience
Message 5 of 16
etfrench
Measure sketch-curves.  It would be nice to copy the results in order to paste into a spreadsheet.
ETFrench
Message 6 of 16
Thanks, @etfrench I get it now.
What you can already do now is to mouse-drag select the text in the dialog:
mouse-drag selected textmouse-drag selected text
Then use ctrl-c (right mouse-button does not work - I have to check why not) to copy the text.
Then paste into spreadsheet. Done.
But I see some room for improvement: the result text can only be copied as a whole. To be able to copy only the numbers would be better. So I will check that -> "under review"Smiley Wink
Thanks again!
Message 7 of 16
MichaelT_123
Hi Mr.Steinbach,
I do not want to diminish your work, quite contrary. ... very well done ...
However, the measuring functionality should be the intrinsically based within the core code of F360.
There are many reasons, some of them are so obvious that we can not even spell them out.
Some others are not so obvious, like reliability, legal requirements, liabilities, etc.
Nevertheless, I hope that your work will trigger some response in TF360 and we will have the additional button in the current measuring tool called Accumulate.
With Regards
MichaelT
MichaelT
Message 8 of 16
An update was released today - mSt sketchTools can also be used in UI preview mode, located in TOOLS:
UI preview mode "TOOLS"UI preview mode "TOOLS"
Please note that UI preview (and the API) is still under development, so the add-in will be released as a temporary quick-fix.
I would like to thank the Autodesk app review team (Application QA) in India for their support.
Message 9 of 16
Update available: Version 1.1.0, 4/29/2019
- Command added: "Source of sketch geometry"
- Toolbar customizations ("Pin to toolbar") are saved
Download from Autodesk App Store
Support Page
Message 10 of 16
grhall28
This no longer shows up on my toolbar but still shows installed on machine.  Any ideas on a solution?
Message 11 of 16
Hi Glenn,
the add-in should show up under TOOLS (see message #8 - the former UI-preview is now the production-UI) .
And it´s for WIN64 only (no Mac).
You can try to reinstall the add-in. The install procedure was done by Autodesk so I don´t know the details.
Hope this helps.
Message 12 of 16
grhall28
I checked all the menus the other day and I don't see it
Message 13 of 16
@Anonymous wrote:
Hi Glenn,
Hope this helps.
To be precise:
reinstall = in Windows first deinstall the app, then install it (mSsketchTools_win64.msi) again.
Message 14 of 16
Unfortunately your add-in is not (no longer) available from the Autodesk App Store. I've also tried your website and am presented with an "Under Construction" icon.
Best regards,
Leslie
Message 15 of 16
bjomag
I thought I finally had found a solution to my problem of calculating pipe lengths but could not find your add-in.
Seams you have done a awesome add-in hope it will be back either as an add-in or as a native feature of Fusion 360.
Regards Björn
Message 16 of 16
eteoka
Observer
Observer
Having the same issues. Trying to make an Extractor Manifold...
