1/12 메시지
I have a design with two components: a panel and a connector. The connector mounts on one side of the panel. I need to transfer the drill hole locations to the panel. I also want to extrude the rectangular shape drawn on the front face of the connector into the panel to thin the panel where the connector will be placed.
I can get an extrusions through the panel and to a depth in the panel to work to work. (Only the holes have been extruded in the included figures.)
The connector will likely have to moved because of other considerations. When I move the connector, the extruded features remain in their original location.
How can insure that the extrusions move with the connector?
해결되었습니다! 솔루션으로 이동.
