Editing unopened sketches?!
patmat2350
patmat2350
I can't find any info on this subject, so I'll ask: Should I be able to modify an UN-opened sketch?
I can, and don't like that I can. All sorts of unexpected errors can result, like accidentally dragging or deleting a feature in an unopened sketch.
Is this supposed to be possible, or do I just have unwanted superpowers?
g-andresen
This is (unfortunately) possible.
günther
patmat2350
Thanks. Seems to be 100% unacceptable, but I'm sure the design team has a good explanation...  🙂
davebYYPCU
Your super powers only work on undefined geometry, (blue / orange)
if it’s black, green or purple geometry, they ignore you.
Might help....
patmat2350
Ah, that's better then. I have been able to delete black lines, but I think they were undefined in length (though that still shows black!).
davebYYPCU
Delete?
that works everywhere.
Things go bad if you push past a warning.
Might help....
jeff_strater
yes, this is intentional.  A few operations, such as dragging, deleting, and editing dimensions, are available outside of sketch mode.  This is a convenience feature, because it can be time-consuming to go into and out of sketch mode, and if we were to disable this "unacceptable" behavior, I suspect the outcry would be very large.  If you are concerned about inadvertently doing this, I'd recommend turning off the visibility of those sketches.
Jeff Strater
Engineering Director
