For everyone that wants a wrap function in Fusion....
PhilProcarioJr
Mentor Mentor
Message 1 of 117
PhilProcarioJr
Been working on easy ways to do this....more to come later....
Here is a sample model with results. I could have done any pattern or design just chose this because it has been asked for so many times.
This took about 2 or 3 min to do.
Phil Procario Jr.
Owner, Laser & CNC Creations
Replies (116)
Message 21 of 117
PhilProcarioJr
Some more examples of "ACCURATE" placement of surface details on a model.
Phil Procario Jr.
Message 22 of 117
michallach81
So they (devs) doing quite well with bending in SM.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 23 of 117
Beyondforce
1. Sorry for missing the point!
2. "Couple of sketches for 3D-rail. Plane along the path. Sweep, Loft or Pipe. Mirror and Circular Pattern. Combine using Cut." - Nop, my way is much easier!
3. Here you go:
Ben Korez
Fusion 360 NewbiesPlus
Gript.app
| YouTube
Message 24 of 117
michallach81
It's not possible to be made automatically in Fusion with the current build. You can do both cylinder and flat piece separately. Knowing the angle of lines on a flat part you can draw correct coil.
Any other way is not accurate.
Michał Lach
Designer
co-author
Message 25 of 117
PhilProcarioJr
@michallach81
"So they (devs) doing quite well with bending in SM."
For me this is a love hate thing....
On one hand what they have is "Extremely" promising, on the other it leaves you wanting a lot more functionality.
For instance I "REALLY" wish the first round of tools included loft tools...I understand why it is not going to but still.
I also wish the pattern geometry tool worked in sheet metal...currently only pattern sketch works.
They are off to a great start and I think in a year or so sheet metal will be a very nice set of tools.
Currently the main focus is on the flange tool and I have been able to get some real usage from the current tools.
So far the flatten tool works really well and looks to be very promising. I have found a few limitations and bumps in the road but nothing really bad.
It has been able to flatten things I never thought it would be able to so kudos to the peeps behind the flatten tool.
The main drawback is you have to have a flat surface in your model. I would rather they based it off a construction plane, but as you can see I have been able to work around it.
Phil Procario Jr.
Message 26 of 117
PhilProcarioJr
@Beyondforce
You have still missed the entire point of this thread, troll a different thread please, I have work to get done....
Phil Procario Jr.
Message 27 of 117
Aadithya01
Oh my god .. This is actually a Toroidal Bend Functionality like in Pro-E . Awesome man how did you do it
Message 28 of 117
Aadithya01
Also how do we sign up for the beta version of SHEETMETAL . Could you tell us the procedure
Message 29 of 117
Aadithya01
How did you sign up for the beta version of sheetmetal . COuld you please tell us the procedure
Message 30 of 117
PhilProcarioJr
@Aadithya01
Go here to sign up:
https://forums.autodesk.com/t5/preview-functionality/how-to-sign-up-for-preview-technology/td-p/6853...
But be warned as of right now they are not sure if the things created in the preview will work with the final release so I would advise only using it for testing and learning.
I plan to make a video soon showing how to do these things using sheet metal. Be patient I am very busy at the moment.
Phil Procario Jr.
Message 31 of 117
Aadithya01
Can you tell us how you enrolled for the Beta version of sheetmetal in Fusion 360
Message 32 of 117
Aadithya01
Oops I didn't see it .. Thankyou so much
Message 33 of 117
PhilProcarioJr
Here is a short video....the surface details are stretched to a fairly accurate degree based on some real world tests I performed. The goal for me with these tests was to have a flat sheet metal design that accurately shows the deformation of surface details from a flat piece to a bent or curved piece as I rarely ever bend stock steel in my work at home. I also needed to be able to bend complex carved wood to bent wood forms. This technique is also proving to be very useful in my CNC laser work, but more on that later....
Phil Procario Jr.
Message 34 of 117
PhilProcarioJr
Another case...
Phil Procario Jr.
Message 35 of 117
LMD001
@PhilProcarioJr
Hello Phil,
Out of the box thinking, I wanted to do "Phil Rocks" as text, but I used this instead. (you still rock!).
My rough attempt...
Nice way to wrap text also.
Screen Shot 2017-02-08 at 15.54.41.pngScreen Shot 2017-02-08 at 15.55.06.png
Best regards,
Ludo
Message 36 of 117
HughesTooling
Also a workaround for text on an arc, used to use this in Geomagic.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 37 of 117
PhilProcarioJr
@LMD001
Thank you!
Yes, I am finding infinite possibilities using these techniques. It will open up a bunch of new possibilities in making models.
I'm currently testing a use case that seems like it is going to work and if it does this will be awesome.
I do however feel I am going to break Fusion in a very bad way if I keep pushing it's limitations farther and farther....
Phil Procario Jr.
Message 38 of 117
PhilProcarioJr
Sheet metal spline test with surface details:
Phil Procario Jr.
Message 39 of 117
HughesTooling
Here's another use.
Mark
Mark Hughes
Message 40 of 117
Aadithya01
HEy @PhilProcarioJr
My humble request is kindly make some video tutorials , start a youtube channel and teach us sheetmetal modelling . Tips and tricks , etc .. Once you are free . I hope that will help lots of Fusion users in some way or the other
