Project Cache doesnt work for some projects
I am trying to cache some projects and it doesnt work with at least one.
Just specific projects doing this.
And i dont know where to look in the log files
and i see this quiet often:
fengka
Sorry to hear that it continues showing the warnings. The message is trying to inform that there are some top assembly designs in the caching project contains referenced designs in other projects which you can't access to, and prompt you to cache it. There might be reasons:
1. You may not be a member of the other referenced projects.
It might because some project member insert some designs from other projects which you are not a member.We are activity working on a feature to accosicate you to request the access permission with just one button click in the future. It should be available soon in the coming months.
But before it is released, there is a quick suggestion that may be helpful to solve problem. If you know which projects you don't have access to, try to contact the project admin to invite you as project member and that will solve the problem.
2. The other projects may be archived by your project team member.
So far there is no automatic way to re-active those projects. You may need to restore the archived project. Go to the Projects page in Fusion Team adn select the filter ARCHIVED. Hover over the project row. Click the drop-down menu > Restore. The project will now be available.
If none of above options can solve the problem, would you mind to provide more usage situation to help us to diagnostic problem?
  • Is your project in team hub or personal hub?
  • Is there any other members in your project?
  • Do you have large assembly in your projects?
  • Have you deleted any projects?
Kaven Feng from Fusion Development Team.
Kaven Feng
Technical Support Specialist
I am the project administrator of all those projects 😄
ok done....
found the reason
thanks for help 😄
