Flatten body to mill on a plywood panel
pietro.rossin
Message 1 of 13
pietro.rossin
I modeled a fuselage in design. It has lateral panels that are flat and top and bottom derived from an airfoil  and then completed with spline. All panels are bodies inside a component.
I need to flatten these top and bottom curved bodies so I can profile-cut them in CAM.
I searched and tried some solutions that pass trough sheet metal without success.
Could you point  me to some solution?
ThanksTwo panelsTwo panelsbottom viewbottom viewtop viewtop view
Replies (12)
Message 2 of 13
davebYYPCU
If your curved portion is actually arc or tangent arcs, you can make the flat pattern,
You can not unfold or make a flat pattern from spline curves.
Might help....
Message 3 of 13
g-andresen
1. are you talking about profile gluing?
2. please share the file of a typical part.
File > export > save as f3d on local device  > attach it to the next post
günther
Message 4 of 13
TheCADWhisperer
@pietro.rossin wrote:
...and then completed with spline.
Spline based geometry will flatten if created properly.
Attach your file here as suggested.
Message 5 of 13
g-andresen
that can be done this way.
However, I recommend creating the cut-outs in flat state.
günther
Message 6 of 13
pietro.rossin
Thanks for help, here is the file.
I'm a hobbist, not engineer.. So don't be cruel 😉
Message 7 of 13
TheCADWhisperer
First thing I wonder about when I see something like this is, "What is the manufacturing/design tolerance?"
You have a curve that is close to horizontal, but not quite a simple horizontal line.
Now, if it has to be as it is, it has to be as it is...
But, if it can be a horizontal line...
Message 8 of 13
g-andresen
 just take the stretched length with the measuring tool > done.
günther
Message 9 of 13
pietro.rossin
Is this sketch5? It could be flat indeed but as I said I'm not an engineer, and I didn't imagine that I went across troubles sketching this way.
Message 10 of 13
pietro.rossin
You mean I create a rectangular sketch with that length and mill it?
That could be a way, I must project the holes in some way on this new sketch..
The one in front of the fuselage has no problem, the one on the back could, It must correspond to the reinforce underneath it...
Message 11 of 13
g-andresen
Such a profile with a thickness 1,6 mm is glued to the side panels without prior bending. So take the stretched length and the width of 50 mm, cut out the triangle.
günther
Message 12 of 13
pietro.rossin
So with my design there is no way to flatten that curved body by using some fusion 360 tool..
Which way do you suggest to design this kind of bodies?
Pietro
Message 13 of 13
g-andresen
Follow the path I have described above.
1. create a blank with the plate (1,6mm) with the length (measured stretched length) and the width (50mm)
2. if it is to be made with CNC, put the sketch for the desired cut-outs on this plate and generate the necessary tool paths for the machining.
With all due respect, this is as shooting at sparrows with a cannon.
günther
