Pattern on irregular/organic surface?
hi,
Is there any way in fusion, to create a pattern along a surface created between two 3D spline paths?
I have an organic shape in fusion. It was imported as an STL mesh and converted to BREP. I created a spline curve that follows a surface contour on the shape, then a separate spline curve that follows a similar path, but roughly parallel to the first. I then lofted between those two splines to create a surface that twists and turns sort of like a ribbon or streamer.
I'd like to create a series of circular features directly on that surface, at regular spacing. Is that possible?
Thanks, lee
jhackney1972
Attach your model and we will see.  If you do not know how to attach your Fusion 360 follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
lalkAGGCF
Hi, sorry for the delay - I didn't have access to the files over the weekend. I've attached the .f3d file here.
Thanks again,
Lee
