Pattern on irregular/organic surface?
04:50 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hi,
Is there any way in fusion, to create a pattern along a surface created between two 3D spline paths?
I have an organic shape in fusion. It was imported as an STL mesh and converted to BREP. I created a spline curve that follows a surface contour on the shape, then a separate spline curve that follows a similar path, but roughly parallel to the first. I then lofted between those two splines to create a surface that twists and turns sort of like a ribbon or streamer.
I'd like to create a series of circular features directly on that surface, at regular spacing. Is that possible?
Thanks, lee
