Filling a complex spherical hole
7 REPLIES 7
Message 1 of 8
jeff.a.longo
410 Views, 7 Replies
I have this model of a controller imported as a STEP file. I would like to fill in the joystick opening (essentially, complete the sphere) shown below.  I've taken a few different approaches that have been unsuccessful.
I tried using the "patch" surface feature. This seems to work pretty well in that it completes the shape that I want.
Now the problem I'm having is joining these two bodies, the controller and the patch, into one unified body. I first tried using the thicken option on the patch surface to give it the right depth then using the body join feature. This fails because there isn't a clear overlap. I then tried unstitching the controller, then stitching the patch + controller back together. The restitching always fails because of how the patch aligns with the joystick opening, even if I increase the tolerance to the maximum. I can never get the restitching to return a solid body.
Any tips on how I can complete this operation? I've attached the .f3d file.
Tags (1)
Labels (1)
7 REPLIES 7
Message 2 of 8
hamid.sh.
in reply to: jeff.a.longo
I simply deleted some faces, patched and stitched:
File is attached.
Hamid
Message 3 of 8
wmhazzard
You could also revolve and join a sphere.
Message 4 of 8
jeff.a.longo
in reply to: hamid.sh.
This is perfect! Thank you for the very fast response.
Message 5 of 8
jeff.a.longo
Is it possible to resolve the "seam" edge between the patch and the body? I'm putting a new hole into the body and am noticing issues with things like filets when they approach that seam.
Message 6 of 8
hamid.sh.
I am not at computer now but you may have luck with selecting these faces in my file and hit Delete on keyboard:
Just keep in mind you should have selected ALL of the relevant faces, not just the two I have marked, so Fusion knows your intention is to remove those face sections rather opening the body (I guess you should select 4 faces, not sure though).
If that doesn't work, just remove all the faces of that dome and make a new one with Revolve like @wmhazzard suggested.
Hamid
Message 7 of 8
hamid.sh.
Here is the revolve version, though it's not clear for me the original outer surface was spherical in the first place. Also I might not have found the profile carefully enough. Check the sketch and adjust to your need:
Another (simpler but non-spherical) method is delete all face above fillet and Patch with Tangent continuity:
Hamid
Message 8 of 8
jeff.a.longo
The patch tangent feature is fantastic! Thanks again for your suggestions.
