I have a box and need to copy a hole plus the tube to two adjacent walls. I tried to mirror the tube to the targeted plane and it doesn't work.
How do I go about doing this?
s
Solved by davebYYPCU. Go to Solution.
Please attach your model so the Forum users can help. If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
Good job with the Origin in the middle.
Cancel the mirror.
circular Pattern all four in one go, using Z axis from the Origin.
Might help....
Got it thanks! I used the Circular Pattern. I then had to pick the hole, I believe it was Type:Faces, then origin as axis. After that was done, I used Circular Pattern again, and used Type:Bodies to select the tubes and using the origin as axis.
Type - Features
select from the timeline, select the hole and the tube, but
you could have made a side panel, and selected body.
Might help for next time....
