Fillet only part of the way
CreekWalker
CreekWalker
As you can see on the image i only want to fillet at the round "thing" not all the way around.
(Only the part at the arrow should be fillet)
Im a real beginner so a step by step or so would be appriciated. 🙂
I can select the blue line, but when i click fillet all the way around is selected
Uber beginner
TheCADWhisperer
What happens if you change the order of Fillets?
Fillet the circular edge of the cylindrical feature last.
CreekWalker
Then i get the oposite problem, then the hole goas all the way around instead.
Uber beginner
PhilProcarioJr
@CreekWalker
Uncheck tangent chain...
Phil Procario Jr.
Owner, Laser & CNC Creations
TheCADWhisperer
Can you attach your *.f3d file here so that I can experiment?
CreekWalker
When experimenting with this "Tangent chain" it worked, thanks (^_^)
This is my first 3D model so its a steep learning curve =P
Uber beginner
