Fill gap between two bodies
prgbrowne
prgbrowne
I have split a body into two bodies, and now would like to fill the gap between these bodies.
I don't want to just move one body as it will deviate from the design.
Is there a way to automatically fill the gap?  Ideally, I would like to have the gap filled with a fillet or a curved blend between the bodies
etfrench
Extrude -To Object should do the trick.
ETFrench
davebYYPCU
Sketch on the left side of the panel (right side is not vertical)
Project the two straight lines, 2 tangent arcs, to fill the gap, and extrude to the other side.
Might help....
