Filet / step on curve between two surfaces
aadee92
aadee92
Hi, how do i create a filet / taper between two surfaces, along a curve.
Basically i'm wanting to model the slim taper between the two arcs (on the edge of the screen) in the image. I'd like to do it parametrically, but maybe its not really possible that route. Any solution would be appreciated though.
Austin
etfrench
Does a two direction chamfer work?
ETFrench
chrisplyler
I think that perhaps you will want to Create>Loft with the desired profiles to cut away the bevel as desired.
aadee92
I think that is exactly what I wanted. Thank you so much! Smiley Very Happy
