- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm a newbie in F360, up until now I have been using Onshape (but due to their announced plan changes I am abandoning them), and I am struggling a bit with the organization of a design in F360.
I have learnt (or rather: read) that one should use components for anything that is supposed to be a separate part/component, and that each component then has it's own sketches and history/feature line.
Now, suppose I do this:
1) I create a new design, and immediately a new component. I add a sketch to the new component, and extrude a body
2) I create another component, then add a sketch to that component, and extrude a body
Now I have one base component (the default one at the top hierachy), and the two newly created sub-components. Assume now I want to extrude a hole in both of these components (say for an axle or something). It seems there are several ways:
- Create a sketch under the top component, and extrude that, cutting the bodies of both sub-components
- Create a sketch under either sub-component, and then extrude cut both bodies with that
In both cases, both components (and the top component) gets a new feature in the history line for the extrude cut, but there is an annotation that says "Multiple", obviously telling me that this feature is affecting multiple components.
Now, it seems the end result is the same, but the cutting profile sketch is in different places. I guess one way might be better than the other, but I don't really know which, and why. Are there any best practices for this scenario?
Coming from Onshape, F360 is a wildly different beast to tackle, so I apologize if this was a stupid question.
