Surface manipulating
meister_mischler
Message 1 of 8
meister_mischler
On this body shell I would like to add some detail: Along the intersected profile I need a tiny offset (approx 0.5mm, which represents a removable hood). How can that be done?
Thanks for any hints. 🙂
Replies (7)
Message 2 of 8
promm
@meister_mischler,
Since you already have the surface you want to use to make the parting line for the hood, I would simply thicken the surface 0.5mm and then do a boundary fill to remove that area.  Please see attached link to a video that goes through this workflow and let me know if you have any questions.
http://autode.sk/2emrawj
Cheers,
Mike Prom
Message 3 of 8
meister_mischler
Hi Mike
Thanks for the video. It shows more or less what I actually did. But I did it in "Model" mode instead of "Patch".
After the body is cut into three parts (front, profil section and rear), I tried to thicken the profil section. I worked along the sculpted surface. But in the lower part, where I cut off a slice to form the final body, it did not work.
So what exactly should I do the the section part?
Message 4 of 8
promm
@meister_mischler,
Can you share some images or the file so that I can walk you through the steps of what to next?
Cheers,
Mike Prom
Message 5 of 8
TrippyLighting
Or perhaps a screencast would be even better.
Message 6 of 8
meister_mischler
Hi Mike
Here you go: http://a360.co/2fthr9F
Thank you in advance 🙂
Kurt
Message 7 of 8
promm
@meister_mischler,
I have the model and I can split it into two bodies.  Can you please walk me through the next steps that you are looking for help with.
http://autode.sk/2fYBTlY
Mike Prom
Message 8 of 8
meister_mischler
I was able to extrude a profile along the path. Then I subtracted it Form the body shell. It worked. 🙂
Thanks for your hell. 🙂
