extruding on a path
extruding on a path
captain455everglades
Observer Observer
Message 1 of 9
extruding on a path
Observer
Observer
I am trying to extrude on a path or angle and not having an luck Screenshot 2024-11-18 at 1.25.14 PM.png
[Post title modified by CGBenner 11/21/24]
Replies (8)
Message 2 of 9
CGBenner
@captain455everglades
Hello and welcome.  I've moved your post to the Fusion Design forum for better results.  Can you give a little more information on what you would like to do here?
Chris Benner
Message 3 of 9
laughingcreek
not a lot of info to go on here.
Message 4 of 9
Observer
Observer
I am trying to extrude the hole on the top to the one one the end for a
Message 5 of 9
jeff_strater
"I am trying to extrude on a oath or angle and not having an luck"
Assume you mean "path" (not "oath").  Check out Sweep:  Sweep Reference
Jeff Strater
Engineering Director
Message 6 of 9
Observer
Observer
I would like to make a hole from the top of my piece and needs to come down
and make a 90 and go out the other side ##- Please type your reply above
this line -##
Message 7 of 9
jeff_strater
If the circles on either end are the same size, use Sweep, as I suggested.  If they are different sizes, use Loft with Centerline (for the path).
Jeff Strater
Message 8 of 9
laughingcreek
you don't "extrude" on a path.  you can "sweep" on a path.  I don't see a path in your pic.
maybe best to attach your .f3d file
Message 9 of 9
CGBenner
@captain455everglades Hello, do you still need help with this question?
Chris Benner
