Externalize internal components
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have an assembly in which all components are internal. What I need is a version of this assembly in which all components are external. The main benefit for this would be in the CAM work as it would be a lot easier to do the CAM for each individual component.
But I find that there is no one click option to make this externalization in place, so that the external component would retain the internal component's position relative to the others or e.g. joint relationships.
What I can do is export the component (native format) or save a copy, whatever may be the difference between the two methods, and then insert it back in the assembly. But now I have to figure out the proper snap points so I can position it in the original component's position. Tedious to say the least.
Why is there no "externalize" command? Any add-in that can do this?
