Unable to select previous version for derived component
seanfrisbey
seanfrisbey
I know this used to work, I would use it regularly. I used to be able to right-click a derived component in the browser (the tree), and there used to be an option to select what version I wanted that derive to be based on. That appears to be no longer available?
jhackney1972
I believe the function your refer to is still there, it may be executed by a different process than you are used to.  I show the process in the attached video.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
John Hackney, Retired
seanfrisbey
I don't have that "History" option 😭 even though my derived parts many many milestones in their history. This worked on this file in the past. The only thing that has changed it that I updated Fusion last night after about 4 months of not using it. Maybe its paywalled?
seanfrisbey
Ooooo, I have found it. The way I derived it, somehow my highest level component had the option. It's there now. Thank you!
