This is a print for a casting and I can't find the solution to proper draft angles on text and shapes such as my file attached.
The draft function creates errors instantly on anything that's not a simple shape in my experience.
Same with including the angle in extrusion.
I've tried the loft function but that is a clunky workaround that doesn't work well enough.
I could use about 10 degrees of draft, and I don't care if the shapes begin to mash into each other.
There must be a way!
Thanks for the help.
