Export several bodies as one single STL
odolyte
Message 1 of 23
odolyte
In the below case i have 3 separate bodies but that need to be printed all together as one single STL.
So we need to be able to select these 3 bodies + right click "export as one STL".
Moebius Factory
Replies (22)
Message 2 of 23
BrienKing
You can do this right now, however, it's not very intuitive.
Turn OFF all the bodies you don't want to export, then RIGHT click on the "Deathly Hallows V1".
From there you should see a "Save as STL...".
Select that and a dialog will come up which will allow you to save all the bodies into a single STL file.
Brien King
spammehere@arcaderestoration.com
http://www.arcaderestoration.com
Message 3 of 23
odolyte
Nice to know ! Thanks !
But as you said not very intuitive 😉
Moebius Factory
Message 4 of 23
schneik-adsk
Kevin Schneider
Message 5 of 23
eric_strebel
While I think this is a good idea, it can cause problems.
When you submit a project to a protoyper it needs to be a seperate file for each object, otherwise they print all the objects in the same file toghether and then you suddely don't have moving parts any more, they all get built as one object.
So...it would be better to be able to select multiple objects at once but have the software make seperate files for each object.
Message 6 of 23
BrienKing
Eric, that is already an option.  You can save to a single STL file or multiple STL files.
And when it comes to 3D printing, there are times when it is more convenient to have multiple bodies in a single file rather than a bunch of files.
Brien King
Message 7 of 23
eric_strebel
Excellent! Thanks
Message 8 of 23
I did this accidentally one time and couldn't figure out how to do it again. Thanks Brien.
Message 9 of 23
mad.macs
I have selected the components I want to export, but I don't see the Save as STL option.
Message 10 of 23
mad.macs
I don't see the option to delete my duplicate post, Is this an option?
Message 11 of 23
daniel_lyall
report yourself to the mod and ask them to do it.
it would help if you post your file I can see one reason from your pick there may be other reasons why the save as .stl is not coming up
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 12 of 23
mad.macs
Here's the file I would like as a single .STL I will be importing into 123D Make before sending it to the laser.
http://a360.co/2etCKco
It's the first file I have shared. Hope I got it right!
Message 13 of 23
daniel_lyall
I can't help, I can not do much with the file it crashes fusion one off the other guys might have more luck sorry
Daniel Lyall
The Big Boss
Mach3 User
Message 14 of 23
xander.luciano
Hey @mad.macs
I can't open the file either, can you export it as a .f3d file (file->Export...) and attach it here for me to try converting?
Xander Luciano
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
Message 15 of 23
etfrench
I just make a single component for printing, then use subcomponents to store all of the bodies.  It's easy and intuitive if you know what I mean 🙂
ETFrench
Message 16 of 23
daniel_lyall
the file needs converted but kills fusion
Daniel Lyall
The Big Boss
Mach3 User
Message 17 of 23
mad.macs
Here is the file. I wonder if the export issue has to do with the Mesh Objects included. One of the pieces gives me some issues with scale if I try to import it to 123D make.
Thanks for looking into it!
Message 18 of 23
Hello Brien
I seems I do not have the option available, it is not active at least.
I was planning to run two materials at the same time so need to save as complete STL
Tried different ways but no luck. Followed some of the ideas on this site but they do not seem to work for me.
Thanks for your help.
Cheers,
George
Message 19 of 23
spongman
this doesn't seem to work any more.
what's the current solution for printing multiple bodies as one .stl ?
Message 20 of 23
etfrench
It works fine.  There are a few rules about it.  You can select the top node in the browser or you can select multiple components when they are subcomponents with the same parent.
See Rule#1 for organizing your workflow.
Share your file or make a screencast if you're still having problems.
ETFrench
