Export on Mac
Export on Mac
Message 1 of 18
Export on Mac
I am trying to export my design for upload, following your instructions.   However I don't have the same file options as recommended.
Attached are the instructructions and my options.
Henry
Replies (17)
Message 2 of 18
My options
Message 3 of 18
lagoc
Observer
Observer
What is Your Mac configuration / model? I'm thinking about buying a Mac mini in the close future and I'm wondering is it correct idea, or maybe I should buy just a new PC.
Message 4 of 18
Its a macbook pro, it is really good especially for the CAD work, would definitely recommend getting one.   However its important to check that all the software you want is available for download on Mac and that (for programs you already have) your license and the software can be transfered.
Message 5 of 18
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Just a quick question for you, does your model have any externally referenced components? This can be indicated by the chain-link image next to the component name in the browser tree. If this is the case, then the option for exporting local archive files won't be available since it will have to export the file as a .f3z file which is not currently available in Fusion. If this is the case, you will have to go to your A360 account and export the .f3z file from there.
If this answered your question, please feel free to go ahead and mark this answer as a solution, that way others can benefit from this thread. Let me know if you have any more questions or if your model didn't contain any referenced files. I'd be more than happy to help!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 6 of 18
Hi James,
Thanks, yes all the components are referenced externally as they in a large assembly file.
How do I access the A360 account?
Henry
Message 7 of 18
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
You can either access it by clicking the triangle logo in the top-right corner of the Data Panel or by going to www.myhub.autodesk360.com. Let me know if this export option works for you.
James Youmatz
Message 8 of 18
Hi James,
I have accessed the account.
My assembly file has not been up loaded to the project in the account.   It is the file is uploading however has not progressed at all.   Can I reset it and re-upload it?
Henry
Message 9 of 18
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Yep. You can do this by following the instructions on this link. Hopefully this works and you can upload the file! If not, please let me know so we can try to figure out a workaround.
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-manually-clear-the-upload-dialog-in-Autodesk-Fusion-360.html
James Youmatz
Message 10 of 18
Im following the process through.
However when locating the file:
Mac:
C:\Users\%USERNAME%\Library\Application Support\Autodesk\production\JobManager360\<Most Current Application ID (sort by date if mutlple)>\
I do not have the folder Autodesk
Any ideas?
Message 11 of 18
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
I don't believe that the folder Autodesk is hidden, but we can check. Further down in the article it shows how to enable hidden folders for a mac. Try that and see if you can find it. If not, I will ask around (I'm a Windows user unfortunately 😞 ).
James Youmatz
Message 12 of 18
Unfortunately that hasn't revealed the folder and I am still unable to find the file to allow me to clear the upload dialog.
Does Fusion not have a built in clear feature?
Message 13 of 18
Hi James,
Thank you for all your help however I now have an even bigger problem.   Please would you take a look at this post http://forums.autodesk.com/t5/design-and-documentation/file-won-t-open/td-p/5808136.
Thank you
Henry
Message 14 of 18
James.Youmatz
Autodesk Support
Autodesk Support
Hi Henry,
I took a look at that link, but I am unsure of what you tried. I would hold off on deleting your local cache as this gets rid of everything that is locally saved. One quick question for you, were you working offline and then came online to save your work? If so this has been known to cause uploading sync issues. Just so I can take a further peek as to what is going on can you please send me your diagnostic log files (these can be found in the help menu in the top-right corner of Fusion).
EDIT: Whoops, I viewed the wrong link originally. Please disregard my first couple of sentences. Just let me know if you started offline and came back online. I'm curious to see if this is the issue.
James Youmatz
Message 15 of 18
Hi James,
Yes I was working offline then when I reconnected the upload error occured.
Attached are my diagnostic log files.
Henry
Message 16 of 18
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
So from your log files it seems that the last time you were able to upload the file successfully was a few days ago. Then an issue occurred where it caused your assembly to have corrupted links and this is when your upload got stuck. Unfortunately, the corrupted links is a known issue that is getting fixed with the September update. Then it looks like when you cleared your upload queue it was empty and that you promoted a working file (v57) and now you have a working file that is not corrupted. Kudos on performing your own workaround! You should be all set to upload these files. Please let me know if you have any more questions, as I did notice you created another forum post that is very similar to this one.
James Youmatz
Message 17 of 18
Thanks James.
Yes all working now which im very happy about.
Thank you for all your help and advice.
I am doing this project for Design For Autodesk.   The project is now complete and I would like to submit it however I can't seem to find where to submit it.
Did you inow where I can do this?
Thanks again
Henry
Message 18 of 18
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
You can go ahead and email your submission to design4autodesk@autodesk.com. I do believe they are accepting .f3z files now too. Let me know if you have anymore questions, I'd be more than happy to help!
James Youmatz
