Explode Text - Problem
Message 1 of 59
What does the error "Could not retrieve the profiles of the selected text" mean while trying to explode text so I can engrave it?  Does not happen with all fonts.  Is there some way to predict which will work, and whick won't?  My work requires the Hypatia Sans Pro font and I can't use it in Fusion 360.
Replies (58)
Message 2 of 59
roambotics_scott
The font renderer is pretty flaky.. my workaround was to create the text in Illustrator, convert it to an outline, export as SVG, and then import (and inevitebly clean up) that.
Message 3 of 59
That's what I ended up doing, but I don't have Illustrator so I located an alternative, installed it, learned how to use it, created my text, exported it, imported it into Fusion about a dozen times trying to get the scale right, cleand up the sketch, and just like that I had my text extrude.
In Solidworks I start a sketch, type some text, click extrude. No need to even explode the text, nevermind jump through a bunch of hoops.
Message 4 of 59
roambotics_scott
Tell me about it. Awful, forces a horrible kludge, and it seems pretty fixable.
Message 5 of 59
What does Autodesk have to say? Anything at all?
Message 7 of 59
colin.smith
Hi @Anonymous
Is that font that you are using a True Type font?
Colin
Colin Smith
Sr. Product Manager
SketchBook
Alias Create VR (aka Project Sugarhill)
Automotive & Conceptual Design Group
Message 8 of 59
@colin.smith, Yes.  It is an Adobe True-Type font, HypatiaSansPro-Regular.TTF
Message 9 of 59
colin.smith
@Anonymous, my understanding is that we should work with True Type fonts, so this sounds like a bug.
Let me take a look in to it and I'll get back to you as soon as possible.
Colin
Colin Smith
Sr. Product Manager
SketchBook
Message 10 of 59
If it is any clue, I am trialing Inventor HSM becasue I am having too many prolbems with Fusion.  In Inventor (2016) this font doesn't even show up.  Does that mean there is something special about it?  Maybe that helps?
Message 11 of 59
colin.smith
Hi @Anonymous, thanks for the additional information, I've got the dev team looking in to this and I will get back to you when I have some more data to share.
Colin
Colin Smith
Sr. Product Manager
SketchBook
Message 12 of 59
colin.smith
Hi @Anonymous
I downloaded the hypatia sans pro font in both .ttf and .otf and neither of the two would show the profile edges.
I get the following result:
I have forwarded this font to the dev team to assess if this is a problem with this particular font, or something deeper.
The work-around in the meantime is to export the needed text from a package like Illustrator as SVG and import it in to Fusion.
Colin Smith
Sr. Product Manager
SketchBook
Message 13 of 59
roambotics_scott
That reminds me @colin.smith - when you fix that, it'd be really awesome if you could also add the ability to control kerning and to have text be centered and autoscale to fill some user specified width or height.
Message 14 of 59
@colin.smith
Ok, thanks for confirming.  Please keep me up to date when you hear something back.
Message 15 of 59
colin.smith
Hi @roambotics_scott
Text in general needs some serious attention. Likely those items you mentioned won't get tackled at the same time as the font issue.
I believe I have seen some of your posts in the idea station on the subject, but if you haven't posted this I would suggest you post it there and I will move it over to the Future Consideration bucket so that I have it when we take a serious look at the text functionality.
Colin
Colin Smith
Sr. Product Manager
SketchBook
Message 16 of 59
roambotics_scott
Understood and thanks, @colin.smith. I had a couple that got archived but will repost.
Message 17 of 59
PhilProcarioJr
The whole text and svg extrusion thing has been bugging me. I do this kind of work all the time and needed a reliable way to do it over and over so I started testing different methods out. I found a way to get any font or SVG file to reliably work in Fusion 360. I downloaded the font you are having trouble with and did a test. It was fast and very easy, and best of all you never need to do any cleanup on the geometry. Its lightweight so it doesn't slow fusion down. There is no need to explode the text or any extra steps. Sadly I can't write up how I did it until later tonight or tomorrow. I will try to make a few tutorials as soon as I get time.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 18 of 59
@PhilProcarioJr, thank you in advance for your help.  I look forward to learning what your steps are.
Message 19 of 59
PhilProcarioJr
Here is another example, no cleanup just filleted the edges. I have tested 85 different fonts all turned out this clean and worked without issue.
I should add that the entire process from start to finish was about 5 min. That included making the svg file from scratch.
Phil Procario Jr.
Message 20 of 59
PhilProcarioJr
I should also add that because I found a "WORK AROUND" it doesn't mean Autodesk doesn't need to refine and fix the text tools, because they definitely do need to work on it.
I should also add that SolidWorks also chokes on a lot of different fonts too and this method works in that app as well.
The two biggest benefits to this method is simple clean geometry that doesn't need cleanup and doesn't bring both Fusion 360 or SolidWorks to an unusable crawl state.
Phil Procario Jr.
