Chamfer the end of a threaded bolt
segallyscott
Message 1 of 13
segallyscott
I need to chamfer the end of this threaded bolt.  I originally drew the bolt with the chamfer then just threaded the shaft.  The thread call out wouldn't lock on until I removed the chamfer because the edges didn'tScreenshot 2022-02-18 115509.pngScreenshot 2022-02-18 115200.png line up correctly.  Is there something technique wise I can do differently?
Replies (12)
Message 2 of 13
TrippyLighting
This is requires a workaround that is as old as modeled threads in Fusion 360.
  1. Extrude the stud.
  2. Chamfer the stud.
  3. Apply the thread to the stud.
  4. In the timeline, pull the thread feature to before the the chamfer feature.
Message 3 of 13
HughesTooling
If you first create the thread as a cosmetic thread, add the chamfer after the thread in the timeline then edit the thread and change it to modelled you'll get the correct result.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 13
g-andresen
When creating a thread, only the lateral surface of the cylinder is captured, but not also the chamfer.
I would do it this way.
günther
Message 5 of 13
patSS3DT
Newbie here.  That procedure causes the chamfer in the timeline to turn red and report: "compute failed".
I checked my work numerous times, have not found any deviation from the solution steps.  What am I missing please and thanks?
Message 6 of 13
g-andresen
Have you tried the suggestion from @HughesTooling ?
günther
Message 7 of 13
HughesTooling
@patSS3DT If the thread has a filleted form like a BSP for example, chamfer will not work.
For a thread with fillets you'll need to create a sketch then use a revolve cut to create the chamfer after adding the thread.
Mark Hughes
Message 8 of 13
patSS3DT
That's exactly the problem!  Neither work-around process worked with a chamfered thread.  I was trying to save time over revolve cut, but fine.  Problem solved, thanks so much.
Message 9 of 13
TheCADWhisperer
@patSS3DT
There is an easier way than Revolve-Cut.
Message 10 of 13
patSS3DT
Thanks.  This is just an arbitrary cylinder - to isolate this procedure as a learning tool prior to making real parts.
Message 11 of 13
g-andresen
try this way, as @HughesTooling   (post3) has desribed
günther
Message 12 of 13
HughesTooling
For fileted threads you can add the chamfer first then delete the face under the chanfer to avoid the need for a sketch and revolve. I think this is what @TheCADWhisperer was going to suggest? See attached file.
Mark Hughes
Message 13 of 13
patSS3DT
Brilliant! Thanks!
