Emboss text in Fusion
owrwaytodoit
Observer Observer
owrwaytodoit
Observer
Observer
I am using Fusion 360, and I want to emboss text on a cylinder. I searched on the website, followed the requirements, but it still did not work, what should I do?
jhackney1972
Take a look at the video, it will explain the process and what I think you are doing wrong.
If this answers your question, please select the "Accept Solution" icon on my post. If you have further questions, please ask.
John Hackney, Retired
owrwaytodoit
Observer
Observer
Hi there, I followed your lines but it still doesn't work
Can you help me find what I did wrong? Thank you so much!
g-andresen
Really?
Take a closer look at 0:10
günther
jhackney1972
It could be the Type Font you are trying to use.  Some fonts are not recognized by Fusion.  Try a simple Extrude on some text in your font, if it extrudes it should work with the Emboss command.  Another thing to check, if you are Embossing from the Origin Plane in the center of the cylinder, the Emboss maybe is being created on the backside of the cylinder.  Turn the model around and take a look.
