Embed Screencasts In Your Community Posts
Discussion_Admin
Alumni Alumni
Message 1 of 11
Discussion_Admin
Assisting another member with complex steps?  Looking to say it with video?  Now you can use Screencast in all of your community posts. This new capability is live across the Autodesk community and we encourage you to learn how easy it is by viewing the screencast in this post.
Try one yourself.  The Screencast desktop app may be dowloaded from the Autodesk Screencast Site.
Let us know what you think and deliver your next Accepted Solution as an Autodesk Screencast.
Screencast:  How to embed a screencast in your Autodesk Community Post
Replies (10)
Message 2 of 11
Too bad it's still really buggy and slow. Smiley Frustrated
Also, you can't embed a screencast into comments/replies of some forums like IdeaStation.
Message 3 of 11
Beyondforce
Hi @Discussion_Admin,
I have already created a tutorial awhile ago on how to install and use AD screencast. The tutorial is pined in the "Tips and Tutorials" section. It will be great if it was pined inside the "Design, Validate & Document" section as well. Here is the direct link:
https://forums.autodesk.com/t5/post-your-tips-and-tutorials/tutorial-how-to-create-a-screencast/td-p...
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 4 of 11
TrippyLighting
What is buggy and slow ?
Message 5 of 11
Discussion_Admin
Buggy and slow how? examples?
How would you use a screen cast in a idea board
DA
Message 6 of 11
Discussion_Admin
Cheers / Ben
I think you just did Smiley Happy
Why don't you post if as a reply to this post
DA
Message 7 of 11
HughesTooling
@Discussion_Admin wrote:
DA
It can be useful to demonstrate a workaround. And you can paste the embed code from the screencast site similar to @TrippyLighting demonstrated in the tips thread with youtube videos using the html editor, see link below.
https://forums.autodesk.com/t5/ideastation-request-a-feature-or/gravity-joint/idi-p/6630862
Mark
Mark Hughes
Owner, Hughes Tooling
Message 8 of 11
@Discussion_Admin and @TrippyLighting
On more than one occasion I've experienced issues with pausing and playback. It seems to get stuck playing and will not pause.
The UI is extremely cumbersome and slow. Editing requires moving to another screen, which then requires placing markers. I imagine most edits would encompass simply trimming from the ends of a screencast. However, to do this operation requires setting four markers and deleting twice and then going back to another screen to save or delete.
Even after one has received an notice saying the SC is ready, it still will not show up in the My Screencasts Public dropdown for another 5 mins. Not to mention I can't simply copy and paste the short URL given to use.
There are many more issues...
Message 9 of 11
TrippyLighting
I rarely edit screencasts. For longer stuff I use another tool (Sreenflow).
I don't see the lagginess or other effects you describe and an as fairly frequent user of the screencast tool (I have made 258 screencasts so far) I must say that it beeing so closely connected to Fusion 360 makes it very handy to use.
Message 10 of 11
Discussion_Admin
Most are not having these kind of issues that I know of. Have you posted in the Screencast board for help\answers?
DA
Message 11 of 11
@TrippyLighting By saying you rarely use a feature is poor argument against that feature being poorly implemented. Also, by saying you use a completely different program seems to indicate you agree that SC could be improved.
I'm suggesting there are issues and much room for improvement.
For example, one bug I've isolated is with a longer SC, if you press play then skip ahead you will not be able to pause. Demonstrated below:
@Discussion_Admin I will post this bug to the proper forum.
