Hi guys,
first of all I´m sorry for my bad english since I´m not an native englsih speeaking person.
I´ve created a Model with multiple joints.
Now I´d like to extend that model. I could simply copy and paste the components and add them to the model, but in my view this is too time consuming.
Is there a possibility, that I can say to Fusion "take these two components and add
them to the end of the model"?
Hi guys,
Solved by jeff_strater. Go to Solution.
Hello @Anonymous ,
You can use the Rectangular pattern option.
From ribbon bar go to Rectangular pattern-->select the Type as component--.select Objects-->select the direction, quantity and distance.
Let me know if this helps. Do like the post and accept as solution if this answers your query.
Thanks!
Hello @Anonymous ,
Thanks!
Hello @Anonymous ,
I am not sure we can copy joints as well.
I will check with the team and get back.
But most probably you need to create joints for the added pattern.
Thanks!
Hello @Anonymous ,
Thanks!
no on both of those questions: It is not possible to pattern joints along with components, and it is not possible to "pin the parameter table to the screen". I apologize if that is "very annoying", but that is just a current limitation.
